Help needed on Holly 650
Old Apr 26, 2008 | 09:59 PM
whitesnake81's Avatar
whitesnake81
Default Help needed on Holly 650
I have changed the carburator on my 1970 Vette from a Holly 600 to a Holly 650 double pumper mechanical secondaries. My problem is the vaccuum hookups. I can't use the space provided on the intake manifold, which is an Eldebrock performer, due to the carburator sitting too close to the manifold to be able to use a fitting for the vaccuum hookup. I only have 1 vaccuum source on the carburator which is at the back and will be used for the PVC valve. I stll have to have vaccuums for the brakes, lights and wipers.
Any help with this problem will be greatly appreciated.
Old Apr 26, 2008 | 10:27 PM
gve's Avatar
gve
You could run a hose off the carb and then use a T to supply the other items
Old Apr 27, 2008 | 08:32 AM
corvette744's Avatar
corvette744
Old Apr 27, 2008 | 11:02 AM
birdsmith's Avatar
birdsmith
....Or you could plug the original vacuum port on your intake, then drill and tap another hole in a different location. (That is if you don't mind boogering up your intake)
Old Apr 27, 2008 | 02:04 PM
whitesnake81
Thanks For Your Help
To Help needed on Holly 650
