Does anyone have a torque spec sheet?
Old Apr 27, 2008 | 07:27 PM
72TTop's Avatar
72TTop
Default Does anyone have a torque spec sheet?
Someone posted a torque spec sheet for C5's, and I have a lot of little questions as I put some of my parts back on. Wonder if anyone has a torque spec sheet for C3, small block? (and the rest of the car). I did a search and found lots of individual questions and answers, but didn't see an overall sheet.
Old Apr 27, 2008 | 07:34 PM
noonie's Avatar
noonie
Never saw one for a C3 but this is good.
Originally Posted by noonie
Here is a chart that is universal.
http://www.morbark.com/Service/belttorque.pdf
Torque is determined by size and class and not application 99.99% the time.
For example:
Chart show 7/16" Grade 8 @ 78#
Chevy service manual shows 80#
That is for a main cap bolt, one of the most critical torques on the car.
Old Apr 27, 2008 | 09:34 PM
Glassbowtie77's Avatar
Glassbowtie77
Here's one for a SBC
Small block Chevy engine torque specs
* Camshaft sprocket: 20 ft. lb.
* Clutch pressure plate: 35 ft. lb.
* Connecting rod cap: 45 ft. lb.
* Crankcase front cover: 7 ft. lb.
* Cylinder head: 65 ft. lb.
* Distributor clamp: 20 ft. lb.
* Exhaust manifold: 20 ft. lb.
* Flywheel: 60 ft. lb.
* Flywheel housing: 30 ft. lb.
* Flywheel housing cover: 7 ft. lb.
* Intake manifold: 30 ft. lb.
* Main bearing cap: 70 ft. lb.
* Main bearing cap (outer, on a 4-bolt): 65 ft. lb.
* Oil filter: 25 ft. lb.
* Oil filter bypass valve: 7 ft. lb.
* Oil pan to crankcase (5/16 - 18): 13 ft. lb
* Oil pan to crankcase (1/2 - 20): 7 ft. lb.
* Oil pan drain plug: 20 ft. lb.
* Oil pump: 65 ft. lb.
* Oil pump cover: 7 ft. lb.
* Rocker arm cover: 4 ft. lb.
* Rocker arm stud: 50 ft. lb.
* Spark plug (5/8"): 15 ft. lb.
* Spark plug (13/16"): 22 ft. lb.
* Temp. sending unit: 20 ft. lb.
* Torsional damper: 60 ft. lb.
* Water outlet: 25 ft. lb.
* Water pump: 30 ft. lb.
And here's one for your suspension
http://www.vbandp.com/instructions/h...specsR0102.htm
Old Apr 28, 2008 | 04:57 PM
mdj21's Avatar
mdj21
theres a torque spec sheet in the back of the factory service manual. if you don't have the factory service manual for your year, it's an invaluable book to buy.
Old Mar 8, 2010 | 02:47 PM
Shadetree C3's Avatar
Shadetree C3
1st Gear
thanks Glassbowtie makes it easier than looking them up in the book. Just about to start putting my 78 on frame back together.
Old Mar 8, 2010 | 03:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Order a chassis service manual. All the factory torque settings are in the service manual.
Old Mar 8, 2010 | 04:19 PM
08vycpe's Avatar
08vycpe
If you have the CD version of the chassis service manual you can print out the torque specs and keep it handy in the garage as a reference without getting out the book each time.
To Does anyone have a torque spec sheet?
