Hydroboost -What is this fitting?
Old Apr 28, 2008 | 12:18 PM
MN-Brent's Avatar
MN-Brent
Default Hydroboost -What is this fitting?
Anyone know what this is for? See red arrow
Appreciate any replies.
Brent......
Old Apr 28, 2008 | 12:41 PM
442olds's Avatar
442olds
The picture is kinda small but it's possible that its a pill for the pressure regulator for the powersteering pump....other than that I can't figure out what it would do.
Old Apr 28, 2008 | 12:46 PM
murraybs's Avatar
murraybs
looks like it could possibly be a bleeder, but I don't see any way to grab it with a wrench.
Old Apr 28, 2008 | 01:29 PM
j schwartz's Avatar
j schwartz
Looks like the brass ferrule for the high pressure hose fitting to me.
Old Apr 28, 2008 | 02:10 PM
MN-Brent's Avatar
MN-Brent
Its got an O-ring in it. The AN fittings do not have o-rings.
Maybe a fitting insert for the power steering box input?
Old Apr 28, 2008 | 06:06 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Here's a thought, call HydraTech and ask them!
Old Apr 28, 2008 | 11:24 PM
corvette744's Avatar
corvette744
Old Apr 29, 2008 | 12:33 AM
MN-Brent's Avatar
MN-Brent
Durango Boy - you got any idea on this one?
Old Apr 29, 2008 | 03:47 AM
CM77's Avatar
CM77
Cruising
On the older hydro boost systems they used an inverted fitting and on the newer style they used the metric fitting with o-rings. I think the part you are looking at is a seat for the inverted style fitting. These were a press fit into the housing of the unit.
Old Apr 29, 2008 | 07:21 AM
Durango_Boy's Avatar
Durango_Boy
Some close answers, it's just the insert into the port in the back of the power steering pump, the high pressure port, that the tip of the hose end seals against. It's there for the later C3s and C4s that have a different hose end than the early C3s.
To Hydroboost -What is this fitting?
