Ported or Manifold Vacuum?
Old Apr 29, 2008 | 06:56 PM
Fscott's Avatar
Fscott
Default Ported or Manifold Vacuum?
I'm a little confused on the ported / manifold vacuum for timing advance. I have a 4 barrel holly with mech. secondary and choke. My timing advance is T'd off the small vac line that attaches to the front right side of the carb. I also have a larger vac line coming off the back of the carb.
Am I using ported or manifold vacuum?
Old Apr 29, 2008 | 07:07 PM
BarryK's Avatar
BarryK
easy to check which it is.......... at idle disconnect the vacuum line off the advance cannister and put your finger over the hole of the hose. If you feel the vacuum sucking on your finger it's full manifold . If you can't feel any vacuum on the line it's ported.
If you have a vacuum gauge you can use that also the same way and it will show if there is vacuum or not at idle.
vacuum at idle = full manifold vacuum
no vacuum at idle = ported vacuum
Old Apr 29, 2008 | 07:10 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
And here's a little more info;
http://www.hotrodders.com/forum/port...uum-23169.html
Old Apr 30, 2008 | 07:22 PM
Fscott's Avatar
Fscott
Thanks for the help. Always good to know these things
To Ported or Manifold Vacuum?
