1972 Air-Con. quick question.
Old Apr 30, 2008 | 07:31 AM
SARASOTA SAM's Avatar
SARASOTA SAM
Default 1972 Air-Con. quick question.
Any ideas how long a charge of R12 will last in a gas tight system before needing a recharge? Thanks.SAM.
Old Apr 30, 2008 | 07:57 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If there are no leaks, the charge would last indefinitely, much like that of the a/c's in our homes. However, since cars use hoses and a lot of o-rings, unlike our homes, it is normal for these systems to leak somewhat and require additional refrigerant periodically. A tightly sealed system should lose less than an ounce a year. Hope this helps.
Old Apr 30, 2008 | 08:17 AM
SARASOTA SAM
Im. with you on that.Reason im asking is after 28YEARS ! ive. not had it recharged ,lately its not been cooling much and yesterday the thermal safety fuse melted.Wondering if a recharge and new fuse will sort it or if a leak is present(hope not).Thinking of trying that Canadian stuff thats suposed to be a direct R12 replacement as must have lost quite a bit over that length of time.
Old Apr 30, 2008 | 08:32 AM
Jud Chapin's Avatar
Jud Chapin
28 years is just unbelievable. Someone must be looking over you. I would suggest putting a set of gauges on the system after you get the compressor going before adding any refrigerant. Your problem could be something other than low freon. I would also suggest staying with R12 as it is still available although not cheap. Good luck.
Old Apr 30, 2008 | 08:49 AM
SARASOTA SAM
YEP! 28 YEARS is'nt the whole story, i dont think it was ever recharged since being built cant be sure but my Arizona service history over its first 6+ years of life shows no record. That makes it more unbelievable.
Will gauge it up as sugested 1st, im lead to believe R12 is blackmarket teritory over here in the U.K.which may be a problem hopefully some one may chime in on this.
Old Apr 30, 2008 | 08:58 AM
cajos's Avatar
cajos
Bloke,
Same over here in the Netherlands. The trick is to look for a industrial refrigerant service station, you know cooling machines, deep freezers. They still have r12. Car ac services don't. Otherwise I know a shop in Belgium!
Old Apr 30, 2008 | 09:03 AM
Jud Chapin's Avatar
Jud Chapin
Hi Sam, I didn't notice that you live in the UK. I don't know what the rules are for R12 there, but it is still available and legal to use in the US. It's just that it is, for the most part, no longer being produced legally in the world. It is widely available on Ebay and I have a supply which I may list there shortly. While prices vary somewhat, it is going for around $25/12 oz. can plus shipping. Jud
Old Apr 30, 2008 | 09:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There used to be an old saying that the refrigerant will only stay in the A6 compressor systems only as long as the front seal on the compressor wants it to!
28 years has to be some kind of record.
Sarasota, before you charge this system you need to figure out what caused the switch to melt! You may have a compressor issue and with the cost of the R-12 you should have this checked before charging.
If you do need to replace the compressor, you should always replace the drier (or desiccant depending on the year and the system) before installing a new one! In either case, if the compressor takes a dump the metal always ends up in the drier.
Wow 28 years! Your front seal must have liked you!
To 1972 Air-Con. quick question.
