OD tranny Q's
Any help would be deeply appreciated.
Randy
Lots of us here on the Forum have opted for BTO Level 2's and 3's. Might want to give BTO a call for more specific questions such as max. RECOMMENDED horse power ratings.
The only gear the 2004R and the THM350 share is third gear. The rest are diffrent.
it's depending on the length of the tranny in the original install....
the 350 MAYBE, but certainly the 400 had THREE differant tail shaft housing lengths...the main body being the same.....so that means 3 differant possible driveshaft lengths on the current install....
obviously depending on the OEM car that tranny came out of....but maybe not even then....on account of the output shafts and housings can be switched in a rebuild...leaving some tag intact on the tranny main housing....
I THINK the 350 also had 3 differant lengths, but I MAY be rong....only TWO that I know of.....
then there is the thm375 which is essentially a 400 tranny with a 350 output shaft/housing.....
just to confuse you more.....
you need measure the LOA of the tranny in there, and go from that .....
