6Al question
Old Apr 30, 2008 | 11:46 PM
V-Rod's Avatar
V-Rod
Default 6Al question
I install my 6al box back behind the right front finder well, but I failled to hook up the tack output. does anyone know what type of input plugs into the outlet. from the manual it looks like a regular male wire connector. Also does anyone know if the white wire that comes out of the middle of the engine compartment wiring harness that runs along the firewall is the tach wire it has a brown connector this in on a 78 L-48 thanks Tom
Old May 1, 2008 | 08:41 AM
V-Rod's Avatar
V-Rod
come on guys nobody knows what type of plug-in that is? I guess I can call MSD but that is not as fun as learning from a CF member. because of the curvature of the wheel well I had to really work to get the legs into the holes or I would pull the unit back out and look for myself. I just thought someone may have on uninstalled or in a place where its easy to see. thanks Tom
Old May 1, 2008 | 08:53 AM
wiseman79's Avatar
wiseman79
Sorry can't help on the wire ID, but from memory the box just accepts a spade connector.
Old May 1, 2008 | 09:02 AM
tonyv123's Avatar
tonyv123
Yeah, spade connector, and the same wire that hooked up to your HEI tach terminal. You may need your tach filter, or not. I'd try it w/o first.
To 6Al question
