spal relay
Old May 1, 2008 | 10:52 AM
V-Rod's Avatar
V-Rod
Default spal relay
does anyone know the pn for the spal fan relay or boush equivalent. spal is not answering I need an extra to hookup to ame fan run when AC comes on and would like to get it before I stick in engine today thanks
Old May 1, 2008 | 11:17 AM
72LS1Vette's Avatar
72LS1Vette
I would think that you should be able to use any 30 amp relay available at any auto parts store. I haven't looked at the SPAL wiring diagram for quite a while but I think the AC fan wire is just a trigger for the relay. Don't forget to put a fuse in the power line also.
Rick B.
Old May 1, 2008 | 03:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I would assume that it's just a regular 30A Bosch relay that's available pretty much everywhere. Wal-Mart might even have them.
Old May 1, 2008 | 04:16 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Why use a second relay? Just tap into the compressor power wire and splice that into the trigger wire going into the relay. Or am I misunderstanding what you are trying to accomplish?
Old May 1, 2008 | 04:23 PM
'75's Avatar
'75
Would that make the compressor engage when the engine temp gets hi enough to turn on the fan?
Old May 1, 2008 | 04:33 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Nope, that's how mine is wired and it works as intended.
Old May 1, 2008 | 11:15 PM
V-Rod's Avatar
V-Rod
Thanks everyone it is just a 30 amp relay and they are avaiable but the spal one has the wires hooked in and is sealed it jsut makes for a nicer looking installation and I finally got hold of them and can one through mail
Old May 2, 2008 | 09:13 PM
thegazman's Avatar
thegazman
Default thegazman
I used a 30 amp relay triggered by the a/c compressor lead to complete the ground from my fan. So, the fan runs anytime I turn on the a/c and the install looks good.
Ken
To spal relay
