Do you know my CAM??
I bought a 76 last fall and found out the motor is not stock, I checked the cam with a dial indicator and a degree wheel on the crank and this is what i got.
exhaust lift, push rod side .268, valve side .415, 255 degree
intake lift, push rod side .281, valve side .420, 270 degrees
the motor is not stock and has some get up and go. are these stock numbers or is this aftermarket. If so how would you rate it, EX. mild, wild, race. It has a slightly noticable lop to the idle but I am still trying to get it tuned.
It is in a 350
