Thread sealant on intake plugs?
Old May 4, 2008 | 10:41 AM
ImBatman's Avatar
ImBatman
Default Thread sealant on intake plugs?
I have three ports that I am installing brass plugs in. Do I use thread sealant or just screw them all the way in? Didn't know if the soft brass plugs would seal on their own in the aluminum intake or not.
Wade
Old May 4, 2008 | 10:50 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I think you're fine without it as these plugs should be pipe threaded. However, I'd use a little sealer anyway.
Old May 4, 2008 | 10:55 AM
ImBatman's Avatar
ImBatman
Thanks Motor gets finished today!!!!!!!!!!!
Old May 4, 2008 | 11:12 AM
Jud Chapin's Avatar
Jud Chapin
You're welcome and good luck with the new motor!
Old May 4, 2008 | 01:36 PM
rcread's Avatar
rcread
I've always used Permatex high temp thread sealant on those, and have never had one leak.
Old May 4, 2008 | 03:12 PM
ShinodaVette's Avatar
ShinodaVette
That's what I planned to use on mine.
Old May 4, 2008 | 04:11 PM
GlockGuy's Avatar
GlockGuy
On my project I used a buttload of PERMATEX AVIATION FORM-A-GASKET SEALANT LIQUID 80019 (as recommended by Trick Flow). That stuff is awesome.
Old May 4, 2008 | 04:45 PM
BigBlockTank's Avatar
BigBlockTank
anything is ALOT better than nothing, pipe thread or not.
To Thread sealant on intake plugs?
