what to expect with 4.11s?
I have a 4spd with 336s now. I'm running 275/60 tires in the back.
How much diff will the car run? looking for more low end torque and to get my motor in its power range: 2200rpm +
what rpm can i expect at 65-70mph?
will the car feel quicker from stop light to stop light or just whine out eveywhere like I'm in 3rd gear.?
I had 355 gears when my car was a stock L82. I rebuilt that rear and swapped over to 3.73s about 4-5 years ago. Last summer I blewn up my 373 rear end. my father had an extra 3.36 rear so I put that in just to get the car going again. I felt the diff just from going from 3.73 to 3.36, the car got a little soggy down low. Because of a lack of funds and time, I ended up keeping the 336s for about a year. Now I have 4.11s coming in for the car.
also I went to the track a few summers ago with 3.73s and my 60ft times were about 2.2-2.3. I either bogged or burned out on every pass lol, I ran 3-4 times. I'm planning on going again this summer at least 1-2 times. Can I expect my 60ft and ET to improve with my gear swap??
thanks
thanks
3.36 to a 4.11 is a pretty healty jump!!!! What is your basic engine setup and what is your max rpm? If you have a decent set up I am sure you would be happy with a 3.70 or 3.90 plus you would need to change your carrier unless you run a thicker ring gear for a 3 series carrier.
IMO a 4.11 is good for a 7,000 rpm engine or better, I have 3.70 in my car and I need to go to a 4.11 or 4.33. You will have a much better low end power but will top out much faster, this also depends on your trans.
Hi L-82kid
now at 70MPH w/3.36 => 2822RPM
70MPH w/4.11 => 3452RPM
Go to this link, you can figure out all option:
http://www.differentials.com/calc.html
But every change in the rear and ration influence the speed reading.
Avner
Avner
example:
65 MPH x 4.11 div/by .006 div/by 13.75 (if a 27.5" tall-tire is used) = 3238 RPM
Back-when my Z28 ran 14.40s @ 97 MPH on 225/70R15 UNIROYALS, it had an almost identical (3.42:1) gear-set:
a switch to 4.11s resulted in 14-teens at the same 97 MPH..... at the time (1984), the track didn't have a CompuLink timing-system, so I can't offer help on incremental-time improvements.
You need to make the engine more powerful instead of worrying about gearing.
My 4 speed 67 Camero has a 2.73 rear end. It can spin the tires a long way in first gear
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
I'm running 4:11's and right at 25.5" Tires, double your RPM's, 3000 is 60mph, 3500 is 70 mph, its pretty close. I'm running a solid roller cam 496 and its good to 7200 rpm's, I don't go above 6500 under normal conditions and the 4:11's are fine. The interstate is another story, need an overdrive. If the motor is not good for at least 6000 rpm's than the 4:11's may not be for you.
Neal
Neal
w/gkull...
I had a 4.10:1 (12-bolt IRS diff w/Moroso posi) for a few months, and tho it did result in improved bottom end acceleration compared to the original 3.55:1, I found the high revs at highway speeds with my 1:1 top gear just too much (not to mention the limited top speed) and consequently had Henry's build me a 3.55:1 (12-bolt IRS diff w/Eaton posi).
Thing is, tho it got out of the hole quicker I doubt it made as much as 2/10ths difference over a quarter mile (not that I drag race my C3), so I suggest another 3.73:1 would likely make you happier overall if you just have to change gears again.
Sidebar: Neal, what cam did you end up with in that 496, if you don't mind my asking?
thanks
thanks
I finally got my car running good. you commented my last post:
http://forums.corvetteforum.com/show....php?t=2005694
The car spins the tires really good now with the 3.36 gears, even gets a little loose when I hit second hard. it just doesn't have low end torque while cruising around, I have to get it over 2500rpm to make power.
I def want to make the engine more powerful but its not in the budget right now. I got the 4.11 rear complete for free, just had to paid for shipping. when it comes in i just have to double check it and put in fresh gear oil.
hopefully next step will be new engine. I already have parts waiting.
I have:
two 350 4 bolt blocks , an extra L-82 crank, new pro topline alum heads, new 1.6 harland sharp roller rockers, XS274S comp cam, and I can reuse my rpm intake, and carb. I just need machine work, pistons/rods, bearings and gaskets. Not sure about 355 or 383 storker.
I had 3.73s before so I know what they're like, the car ran good with them but now I want to try something different. plus the rear I have coming in is a good used one and all set up with 4.11s. Eventually down the road I'll have to build a new stronging rear and then I decide on what gear ratio I want.
Nice I want to feel the difference. I don't go on long trips and I don't really care about the highway anymore. I just want a stop to stop/ 1/4mile for now. Then when I have a little more money Ill put in a 6spd and some 3.73
