1979 steering column plastic insulator??
Old May 5, 2008 | 11:12 AM
Prominus's Avatar
Prominus
Default 1979 steering column plastic insulator??
What is the name of that plastic piece in the steering column that insulates the horn from making constant contact....when I pulled everything that thing crumbled into 1000000 pieces........
also there is a blue relay under the steering column near the fuse box...only 1 I saw there...it was really hot and making a burning smell so I pulled it and nothing stopped working...I replaced it and nothing started working...whats it for??....
last question...well more of a rant....need to change a lug stud cause I broke 1 off putting on new shiny lug nuts....pulled the wheel...and it turns out you have to pretty much dismantle the whole rear end to get to it..... what the helll!!!!!!!!!!!!!!!!!
Old May 5, 2008 | 12:27 PM
marshrat99's Avatar
marshrat99
Horn contact retainer
http://www.ecklers.com/product.asp?p...5&dept_id=1716
Old May 5, 2008 | 03:18 PM
Glassbowtie77's Avatar
Glassbowtie77
I just had to replace mine last week also, it disintegrated when I went to remove it to replace my lock cylinder. Got it from Zip, now it's good for another 30 yrs.
Old May 5, 2008 | 04:56 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Just put mine back together this afternoon, got one from Zip, worked perfectly!
To 1979 steering column plastic insulator??
