TIMING HAS BESTED ME... Help?
Old May 5, 2008 | 09:52 PM
chevr0letman's Avatar
chevr0letman
Default TIMING HAS BESTED ME... Help?
You can not imagine the frustration I am feeling at this point.
I am "trying" to set the timing on my 77 and it is giving me the most unusual results.
Here's whats happening:
Just installed new distributor weights and springs so I can achieve full advance by 2800, thought it was proper to adjust timing. So I start by rubber-banding the weights and disco'd the vacuum can. I start her up and set the idle to around 550. Take a peek with my old timing light (not a dial back) and my timing is at 36 degrees! I don't know what the hell is going on. I decide that ill adjust the timing to 12 degrees btdc to see what happens. I can tell this isn't right at all because my car is barely running and diesels after i kill the engine. Even backfired once!
I dont know what it could possibly be any advice at all is much appreciated.
Old May 5, 2008 | 09:57 PM
Durango_Boy's Avatar
Durango_Boy
Did you remove the distributor when you did the spring and weight change? Is it possible you're a tooth off?
TimAT's Avatar
TimAT
Sounds like maybe the weights are advanced. Make sure they are together. With the rotor off, study which way the dizzy turns (CW) and look at the way the weights move to a CCW direction. CCW is advanced. Make sure you tied the weights down in the correct direction. Also make sure the breaker plate is secure and the vacuum can is extended all the way.
Old May 5, 2008 | 09:59 PM
chevr0letman
no, i didnt remove the dist.
Old May 5, 2008 | 10:29 PM
86Pacecar's Avatar
86Pacecar
Sounds like your balancer has slipped. Get #1 to TDC and see where your timing mark is, probably way off. If so time to replace it with a new one.
Old May 5, 2008 | 10:45 PM
Mike Ward's Avatar
Mike Ward
Are you sure you're on plug #1?
Old May 5, 2008 | 10:55 PM
chevr0letman
positive.
Old May 6, 2008 | 07:46 AM
red70stingray's Avatar
red70stingray
This is the problem.... gaurenteed it slipped and you need a new one...
To TIMING HAS BESTED ME... Help?
