I have removed diff mount nut and removed half shafts... and took out the TWO bolts out of diff cross member as seen in pic. i though at this point i would just let the jack down and down she would come...
couple wacks of hammer and PB and lil pry bar... its not coming down???
I soaked the bushings with PB every day for about a week and then took a pry bar to it under the wheel wells. It took a little "heave ho" but it popped out.
I would suggest leaving the two bolts partially in to catch it when it breaks loose.
i just did this a few weeks ago and had the same problem you do. some one suggested using a gear puller. it worked perfectly.
the arms go on the Xmember and the center point pushes on the bolts you left partially in. took me about 10 mins to get it xmember free and the diff out.
