Cold version of R45TS plug?
Old May 7, 2008 | 01:45 PM
Jay-Dog's Avatar
Jay-Dog
Default Cold version of R45TS plug?
Does anyone know the equivalent to this plug in a colder heat range?
Thanks,
Jay
Old May 7, 2008 | 01:51 PM
jimvette999's Avatar
jimvette999
AC Delco R44TS and colder even R43TS
Old May 7, 2008 | 01:59 PM
Jay-Dog's Avatar
Jay-Dog
Thankyou sir.
Old May 7, 2008 | 04:27 PM
jimvette999
Originally Posted by Jay-Dog
Thankyou sir.
You're welcome
Old May 8, 2008 | 01:33 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
For future reference
R=Resistor
43,44,45 etc= heat range Higher # hotter plug
T=Tapered seat
S = Extended tip (may cause detonation)
If there is a L after the # its a long plug.
Old May 10, 2008 | 12:46 PM
Jay-Dog's Avatar
Jay-Dog
Update: I replaced the R45TS set with R43TS. So far, so good. While I was at it, I checked compression. Each one came in between 170 -175. That's good news to me, I was afraid they could be a bit too high.
Jay
Old May 10, 2008 | 05:00 PM
ENG40's Avatar
ENG40
Let us know how the 43's work. Thats a pretty big jump in heat range from 45 to 43. Did you try 44's?
Old May 10, 2008 | 07:50 PM
Paul L's Avatar
Paul L
Jay
You may wish to go back to the 45s for street use. 44s were recommended back then but were prone to fouling for everyday use. With modern fuels the 43s may be very cold unless you are on a circuit track at constant high RPMs.
Old May 10, 2008 | 08:32 PM
BarryK's Avatar
BarryK
The AC44 plug was standard on the older motors but it's been discontinued. A lot of books reference the AC43 as the replacement but it's typically too cold of a plug for the street, it works better if you are driving with sustained high RPMS. Regular street use tends to have the foul a lot.
i'd go back to the AC-45 or AC-R45
Old May 12, 2008 | 01:39 PM
Jay-Dog's Avatar
Jay-Dog
Appreciate the advise, but most of my driving is highway. Have not fouled out yet. Also, pinging has been greatly diminished. Still need to find non-ethanol fuel. I have a set of R44's in the garage in case I start having trouble. Again, thanks for the help.
Jay
To Cold version of R45TS plug?
