Oil Leak on 71 BB
Upon returning, I noticed a curved trail of oil about eight feet long in one of the bends of my driveway. Then, I looked under the car and saw a puddle about six inches diameter. Note that there was not a puddle after starting the car and letting it run in the garage while working on the brakes a week prior.
Because of the fact that the line of oil in the drive was only around a curve (for the most part), I'm assuming this came out of the hole in the bottom of the torque converter/starter shield which would most likely mean either a bad rear seal on the oil pan or a bad rear main seal. There are no noticeable leaks around the valve covers.
I have already order the one-piece felpro oil pan gasket and the two-piece felpro rear main crank seal just in case.
Tonight, I put her on stands, removed the shield (which did have some oil residue on the inside), and ran for about 10 minutes and did not get any leak whatsoever - just a little seepage at the rear of the oil pan gasket, but no drops (verified there was plenty of oil in the engine first). After this test, I'd like to believe that the rear main is okay, but the oil pan seal needs to be replaced. I probably didn't get a huge leak because the oil was not sloshing around.
Can anyone confirm my assumptions based on my symptons? Any other thoughts?
Thanks!
I believe that the oil was gathering in the flywheel shield, and when I went around the curve, the oil made its way to the hole in the shield and leaked out. The hole is in the center of the sheild, so one would think it would leak out when the car was going straight, but since the curve is right after an incline in the drive, the oil could have been at the rear of the shield and finally sloshed back to the front just in time for me to make the curve on the flat part of the drive.
The way I figure it, it can't hurt to switch to at least switch to a one-piece oil pan gasket. And, since its supposed to be relatively easy to remove the pan, and the parts are on the way, its worth a try.
