Help with drag transmission
Old May 10, 2008 | 02:54 PM
Hybrid117's Avatar
Hybrid117
Default Help with drag transmission
Im building my 1980 L82 to be a strip with some street vet and i need help with picking a transmission. I want a drag set up.
I have 4.11 gears on a 350 motor.
1st is i have a th350, im not sure if its the th350c.
2nd Is the th350 worth rebuilding for a drag set up.
3rd should i go with something that has a OD like a 200r4 or th400?
Old May 10, 2008 | 04:18 PM
V-Rod's Avatar
V-Rod
understand I am not quoteing from experience but research. All the trannys you mentioned are used for drag applications and can be built so. th400 is stronger than 350 but heavier and has I think bigger gear seperation. 2004r has lower 1st gear may be not needed with 4:11 but if you drive on Hwy OD would drop RPM's a lot. I think it all depends on how much HP you are going to build
Old May 10, 2008 | 04:22 PM
Hybrid117's Avatar
Hybrid117
well im just worried with a th350 and 4.11 gears that i would top out way to soon for a 1/4 mile.
Im building about 500hp motor so something to take that.
Old May 10, 2008 | 08:00 PM
JustinD's Avatar
JustinD
With my th350 and 4.10's I could do about 120-130 before I was at the rev limiter (6250 rpms). You would just wind out in the quarter mile with your final gear being only 1:1.
To Help with drag transmission
