Rear brake lines.
Old Dec 17, 2001 | 01:16 PM
MikeC's Avatar
MikeC
Default Re: Rear brake lines. (JRChurch)
If you replace them with flex lines, they can move and possibly get rubbed by or caught in the wheel.
Please don't do this.
[Modified by MikeC, 11:17 AM 12/17/2001]
Old Dec 17, 2001 | 01:34 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Rick
I agree with MikeC. These lines are availabe form many sources in both steel and SS. If GM thought they could get by with one flex line rather than a steel line and a flex line, they would have done it. There are too many moving parts in this area to be fooling around.
Ed
Old Dec 17, 2001 | 01:43 PM
UKPaul's Avatar
UKPaul
Default Re: Rear brake lines. (MikeC)
I've just ordered a set of the braided stainless steel "Aeroquip" style flex lines (so they should be here around late Jan!). If it is possible for them to flap about I was going to use cable ties to secure them out of the way of the wheel. The main reason for fitting them is so that I can remove the caliper from the rotor without having to disconnect the brake pipes & have to bleed it all after fitting it back on (planned lazyness!).
Paul
To Rear brake lines.
