71 C3 Steering Colum
Working on my buddies 71 vette.
He's recently had the body off frame to replace the body mounts and correct door ailnment.
He is a Professional Auto Body Technician. This was not hack work being done.
With that said, I helping him put things back together. I am an Aircraft Technician, with many years of wrench time on cars, trucks, motorcycles, Aircraft, ect. If it's got nuts and bolts, I work on it. I am an **** retentive car guy.
Part of the problem is I'm in Colorado, He's in California.
Anyway, going back together, Steering will not go back together. The shaft appears to have shrunk. What had to be pryed apart is now an inch shy of connecting. While it was apart we replaced the ignition lock, had the colom down at the dash to replace the headlight switch, and some Trouble Shooting on the wipers.
It's not that hard to get it back out. I was able to stick a screwdriver against the ridge at the bottom end and tap it down with a hammer. In the alternative, the rag joint could be bolted back on to use as a tapping/pulling surface.
If he pried it apart, he more than likely collapsed it. You can use the shanks of the rag joint and get a longer bolt and nut and pull it back together. Just go slow and easy!
The standard (non-adjustable) steering shaft length for 1969 through 1976 should be 4.55 inches.
Jim
It's not T/T collum.
He finnaly got it hooked up, but we'd like another 1/2 in, but take what we got.
What was done:
Took the steering wheel back off.
released the lock plate snap ring,
left the tool installed and slacked the compression nut wasy off.
lossened the collum mounting bolts.
put the car on the ground.
used a screw driver as a wedge in the rag joint.
got it!!
THX Again!
