coolant temp sensor
Old May 11, 2008 | 04:45 PM
corvette744's Avatar
corvette744
Default coolant temp sensor
Allright previous motor had the sensor in passenger head.It is a mechanical autometer guage.I have dart heads now and no passage,so i installed guage in the passenger rear port on intake.My problem is i let the engine run for 15 minutes and then drove around -temp guage didnt move.I felt the guage and hoses dont feel hot-warm though.After letting run and cracking nut loose coolant is present no air.While doing this i did notice a big diff in temp between front outlets that have plugs-(4corner water outlets in intake)and the rears.I have the sensor in the rear one.Anybody notice this or were do you have you sensor mounted-mechanical guage.
Old May 11, 2008 | 06:07 PM
corvette744
All right never mind moved sensor to the front outlet in manifold-idles at 190-and with fan on 180 for an hour.FIXED now lets cruise.
SIXFOOTER's Avatar
SIXFOOTER
you need to get a different thermostat housing, one with the port in it. Summit has several of them
Old May 11, 2008 | 06:36 PM
corvette744
No i like were it is in the intake-anyway i just bought a new t stat housing .[IMG][IMG][/IMG][/IMG]Just need to figure out how to mount my fuel regulators nicely
Old May 11, 2008 | 06:37 PM
corvette744
Closeup[IMG][/IMG]
To coolant temp sensor
