6al
Old May 12, 2008 | 06:01 PM
V-Rod's Avatar
V-Rod
Default 6al
where is best place for the switched power source for the box?
Old May 12, 2008 | 07:35 PM
Stroker-427's Avatar
Stroker-427
Try one wire from the connector of the blower resistor.... there is a 12V. switched with 25 Amps fuse!
I don't remember the color..... but with a multimeter should be easy to find the right one....
Old May 12, 2008 | 07:54 PM
dannyman's Avatar
dannyman
I like the fusebox.
Old May 12, 2008 | 08:44 PM
chvet73's Avatar
chvet73
It depends on where you mount the box. I'd look at what is close and easy to get to.
Old May 12, 2008 | 09:03 PM
TimAT's Avatar
TimAT
I'm lazy. I used the switched power lead to the original coil- not the resistor wire-my car didn't have that- it was the old TI (K-66) ignition.
Go to the fuse box- there should be a terminal marked IGN- tap off of that with a wire no smaller than what goes into the MSD box.
Old May 13, 2008 | 03:57 PM
canadian73's Avatar
canadian73
i runned a fusible wire from the main terminal on the starter solenoid . be good
To 6al
