Cross Member Bolts
Old May 12, 2008 | 07:58 PM
corvette_maniac's Avatar
corvette_maniac
Default Cross Member Bolts
Could someone kindly tell me the size of the cross member bolts. Also is there a washer as well? I'm about to mount the diff.....
Sorry ...but the car has been down for quite a while and unfortunately I didn't organize things as I should have.
Thanks in advance.
Old May 12, 2008 | 08:49 PM
corvette_maniac
The only thing that I'm really coming up with is a 1 3/8" bolt with a lock washer. It has a 5/8 head. From the looks of the old cross member bushing, it looks as though there was a large washer too.
Any help would be appreciated.
Old May 12, 2008 | 08:59 PM
TimAT's Avatar
TimAT
A 5/8 head makes it a 7/16 bolt I think. You think it's 1-3/8 long? I'd go get some good grade 8 studs 1-1/2 long and put those in with some good HD flat washers, lock washers and nuts. OR get the crossmenber reinforcement kit from VBP- plated that help the rear crossmember mounts (strength) and all the hardware.
Old May 12, 2008 | 09:46 PM
stpman's Avatar
stpman
They're 7/16-14 not sure of the length as I haven't found the ones I took out ...yet
Steve
Old May 12, 2008 | 10:54 PM
corvette_maniac
Thanks guys....
The diff is in!!
To Cross Member Bolts
