crate motor
Old May 14, 2008 | 07:21 PM
vett 68's Avatar
vett 68
Default crate motor
i have a engine factory complete drop in 383 full roller motor about 460 hp, my problem is the distributor, this one lasted about 40 miles and now it doesn't have enough spark to start, this is the second one it's happened to, i've got an hei tec drive in it has anyone had this problem or know how to fix it thanks
Old May 14, 2008 | 07:26 PM
LFZ's Avatar
LFZ
english?
Old May 14, 2008 | 09:13 PM
OzzyTom's Avatar
OzzyTom
I have a similar motor and HEI tach drive dizzy from engine factory.com
the fact that a replacement dizzy didn't solve your problem makes me lean toward your 12 volt supply to the dizzy.
Check that you have true 12volts available to your distributor, with your key in the "on" position. It should also go to 0 volts when the ignition key is off. If power is on continuously, you will burn out the coil inside the dizzy.
Next, have a look at the plastic socket which holds the three wires coming out of the dizzy base which plugs into the cap. Make sure all three terminals are seated correctly in the plastic socket housing. Tug at each wire and make sure they do not come out of the socket.
I had intermittent issues with my motor due to the red terminal NOT being secured properly in the socket. The red wire provides the 12v supply to the HEI module inside the dizzy.
Also make sure that the socket seats tightly onto the respective terminals on the cap when you insert it.
Where are you sourcing the HEI tach drive dizzy from?
There are some poor quality cheap ones on Ebay at the moment.
I just looked up some of your previous posts..... I noticed you have recently installed a rev limit kit. Have you tried your motor with that kit removed? The problem may be in that component!
Old May 15, 2008 | 01:20 PM
vett 68's Avatar
vett 68
i found a loose red wire connector, not crimped right at factory, will this burn out coil or module
Old May 15, 2008 | 06:57 PM
OzzyTom's Avatar
OzzyTom
Shouldn't burn out anything... just won't provide reliable spark.
Recrimp the connector and it should be good to go!
Old May 15, 2008 | 07:24 PM
vett 68's Avatar
vett 68
it did burn out module i think coil is all right thanks for the help it made it easier to find i have learned alot from this forum this isw my first vettethanks pete
Old May 15, 2008 | 10:11 PM
OzzyTom's Avatar
OzzyTom
OK... I guess the intermittent power to the HEI module may have caused a spike which fried it. Glad you've found the problem.
Always happy to help out a fellow rev head... especially one with a 68 vette
To crate motor
