The car is dumping so much fuel it can't run. If I take the 2 wires like the service manual recommends and jump them, it runs fine. Also got a code 15.
Maybe your a victom of Murphys law. I would replace again, see if it runs better and go with that. If it fails again, the CTS is powered by the ECM. You might have to look into a replacement.
The only thing else that makes any sense is a wiring short, possibly intermittent, somewhat to the CTS connection.
Another thing to consider is to get yourslef set-up with WINALDL (its free-do a google search) and build the cheapie cable for it. This will show you what the ECM is seeing with regards to your CTS sensor, and all others as well. Might give you some info on what is happening.
I changed the sensor, and all is fine. I do need to get off my butt, and build a cable. It would define what is going on. I downloaded the software months ago.
