more crossfire problems
Old May 17, 2008 | 08:28 AM
fitter's Avatar
fitter
Default more crossfire problems
as per the advice of many of you i recently overhauled my fuel injection system to cure a hesitation problem with my '82. what has been completed is bushing of tb, cleaning idle air control valves, new injectors, new fuel pump, new plugs, wires, cap, rotor, tps, o2 sensor, coolant temperature sensor, adjust timing to 8 degrees btdc and adjust fuel pressure to 12 psi. i'm still having the same problem with the stumbling upon light acceleration. any other suggestions? also how do you balance the throttle bodies? anyone know the procedure that they care to explain in detail? thanks in advance!
Old May 17, 2008 | 10:55 AM
MN-Brent's Avatar
MN-Brent
Do a search for user "simpson36". He is very educated on how to get these things done. He has posted a few detailed HOW-TOs recently here, including balancing the CFI TBs.
B.....
