Valve stem seals?
Old May 19, 2008 | 01:20 PM
carpinteriac3's Avatar
carpinteriac3
Default Valve stem seals?
Hey folks -
After a couple of weeks away, I've blocked out the weekend to work on the '77 - it's puffing out a lot of blue smoke, so I'm going to replace the valve stem seals. It has about 124k on the original L48, so this is pretty much way overdue. Got all the relevant tools, compressor, and innumerable handy guides and advice on the procedure. It's a go.
However, I'm having problems finding the right part for the application. The local Napa/Schucks/Kragen/Whatever places don't have them on hand, so I'm stuck with picking them up online. Any recommendations on the right thing to get for the stock engine? I don't want to have to machine them to get them to fit, I'm just looking for something to drop in to replace the originals.
Besides, I want to have a little time free to replace all the hoses and all the power steering bits. Busy weekend!
Thanks!
Old May 19, 2008 | 03:20 PM
johns73's Avatar
johns73
Any part store should have what you need on the shelf. After finding another parts store buy the umberlla type, much better then the o ring type.
Old May 19, 2008 | 03:21 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I like FelPro and installed the umbrella type in my '76. Since you haven't filled out your profile info, I have no idea where you live. However, I would think some local parts house would carry these or be able to get them quickly.
Old May 19, 2008 | 03:52 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Originally Posted by johns73
Any part store should have what you need on the shelf. After finding another parts store buy the umbrella type, much better then the o ring type.
Used these before with great success. I believe they were originally Ford 351 pieces.
Old May 19, 2008 | 05:47 PM
jackson's Avatar
jackson
to clarify:
OE sbc C3 seals are small o-rings that fit into a 2'nd groove cut into valve stem near top of valve stem just above 1'st groove for keys.
aftermarket umbrella seals are fitted below retainer ... that's what carp3 probably needs. FYI, typical sbc valve stem diameter ~ 0.341" or ~ 11/32"
Old May 19, 2008 | 06:55 PM
carpinteriac3
Thanks guys - found what I needed (I think)!
Old May 19, 2008 | 08:26 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Perfect Circle VS-2, hope that is what you found. Ron B.
To Valve stem seals?
