Exterior Door Handle/Release Adjustment
Old May 19, 2008 | 03:07 PM
WillEE's Avatar
WillEE
Default Exterior Door Handle/Release Adjustment
Recently picked up an '82 and in process of getting it roadworthy.
Neither of the outer door hanles will release the door latch so I currently have to leave windows down and reach inside. Both doors release and open when the interior lever is pulled though. It appears I need to adjust the piece of threaded rod coming from the outer handle so pulls more on the release lever. Holy Cow! - this looks like a nightmare to get my hands in this area . Has anyone ever done this and have any tips.
Thanks.
Old May 19, 2008 | 03:18 PM
Durango_Boy's Avatar
Durango_Boy
I have done it...and yes it's very hard. It's easier if you remove the three screws holding the main latch, and let it lower just a bit.
I also used a few long tools to help like a long set of needle nose pliers and long screw drivers.
If you have access to a son or a wife that have small hands, they may be able to help you quite a bit.
Old May 20, 2008 | 04:42 AM
hunt4cleanair's Avatar
hunt4cleanair
I just finished with power door lock repair & restoration but didn't have to do any adjustments. I'm not sure if you've already accessed the area but best approach is with the window down, and remove the black plastic guard. Let it drop into the window channel. loosen the linkage rod that goes to the lock lever and that will give you a window you can access (or that of wife or kids) as Durango describes.
PS...use lots of light and clean up that lock mechanism while you're in there.
Old May 20, 2008 | 11:47 AM
WillEE's Avatar
WillEE
Thanks for all the advise - good stuff! I got the window out of the drivers side cuase I had to take the mirror off to tighten it where mounts to it's pedestal/base. Boy was that fun!!! - Not! But I got it and installed the new outer lower trim piece. Now I'm going-in to adjust these handle mechansms and use the tips you guys provided. My daugher has narrow hands, however, doubt she will see this as beneficial to her recent french manicure. My wife could be a good secondary candidate though. I did remove the black cover and will also loosen the screws for the lock mechanism above before I start. I think I'd rather rebuild an engine vs. working inside these doors but no pain-no gain.
Question - what are the electronic connections for near the door lock cylinders? My pwr dr. locks work from the interior switches but are they supposed to engage when I turn the key too? This part is not working.
Old May 21, 2008 | 03:38 AM
hunt4cleanair
I would say wait for an article coming out in Corvette Enthusiast but it won't make it in print until probably September.
The electronic connections near the door lock cylinders is the anti-theft switch. They key lock and power door lock switch both lock the doors...one is manual and the other electronic. A third system is the door lock **** in the armrest.
If you're saying when you turn the key, and the door does not lock, than I suspect it's a mechanical problem like the linkage is binding or a rod has lost a connection. But when you use the key, it bypasses, or better yet ignores the power lock system but still locks the door.
To Exterior Door Handle/Release Adjustment
