I recently purchased my '82 Vette and am fixing lots of stuff and am now trying to figure out why the wheel moves back/forth sideways between 45 - 55 mph. It's not super bad but definitely out of the ordinary and needs to be addressed. The car has 85,000miles on it and I don't know all the history of maint. First thing I did was had the wheels balanced which did not help. Then I jacked it up and noticed both front wheels had excessive play. (esp. the drivers side). I could hand tighten the bolt that holds bearings in place almost 2 full turns. I torqued each side to 12 ft. lbs. and reinstalled the cotter pins and the problem is still there. I suppose the next step is to replace the bearings and races but looking for any other advise or ideas on what may be causing this.
A couple other ideas I have is a bent wheel or possibly a tire with a flat spot form sitting too long. Any experiences or ideas woudl be appreciated.
You didn't leave them torqued to 12 did you? I guess 12 is OK to seat them then you back it off, snug by hand & insert cotter pin. The balancer should have found a bent wheel or a tire problem, I say should have. Try swapping the front wheels to the back, if the problem persists - it's not the wheels. Check all front end parts for wear/loose, bushings, ball joints, tie rod ends, pitman arm, etc.
I did leave them torqued at 12ft. lbs. Is this bad? Am I supposed to tighten to 12 and then back off to nearest cotter pin slot?
I do know that last owner did have new ball joints and A-arm bushings installed but will check the other susp. parts. I like the idea of swapping wheels and will try that too.
From: Graceland in a Not Correctly Restored Stingray
Back off one flat and re-pin into the nearest hole.
When you say "back/forth sideways" I'm going to assume you don't mean the column is literally moving from side to side, but rather that you're describing a "shimmy" of the steering wheel, right?
Bent wheel or hub shouldn't only show up at 45-55. Flat spots from sitting a few weeks shouldn't remain after just a few miles (months/years may be a different story), and should typically be noticeable at other speeds as well. However, do take the time to carefully inspect your tires as I suspect you may have another problem developing. That was the culprit on my DD recently for a "shimmy" that came and went between 50-70. New tires solved it.
Yes - just the wheel motion is shaking sideways - not the column and don't feel any vibration in the rest of the car either. The previous owner bought new tires (disc. tire road-huggers - not my favorite) about 3 years ago and then the car sat in his garage nearly 100% of the time. Then first thing I did on the way home after buying it was check the tire psi and was only about 20 psi all the way around which probably didn't help while sitting there for 3 years.
That can happen if you have a broken front spring. I had that happen to me on a 72 Impala. I added some spring spacers between the coils on the bad spring and the problem went away.
Could this be related to something to do with brakes? When you hit the brakes does it get better, worse, or stay the same... Mine shook pretty good upwards of 70mph, and much worse under brake load. Warped rotor I believe in my case. But again, much more pronounced under braking.
I suspect tires or rims as well.
50 MPH is the exact speed where tire imbalance or warped rims show up as vibration.
Even when they balance a tire , a warped rim will show vibration while driving, but not on the balancer.
As mentioned B4, swap with the aft tires and check again.
Find a shop that uses the Hunter GSP9700 tire balance machine. This machine virtually road tests your vehicle and tells the installer what position to mount the wheels to eliminate any vibration. If you have a bad wheel or tire, this machine will know!
Is this the machine that spins/balances the wheels while still on the car? If so - I think I know who's got one?
Nope, you're thinking of an ancient form of wheel balancer. The GSP9700 uses a road-force wheel to simulate actual on-road tire behavior. It often picks up problems that normal spin-balancing won't find. (I know a fair bit about that beastie, my cube was across the hall from the guy who designed the software when I worked at Hunter.)
Batty is right.....and I go further in that you have a tread separation/twisted belt problem...common as green grass on older radial tires....evidenced with bulges in the side of the tire, mostly but not ALL visible....
