Questions front end
Old May 20, 2008 | 01:10 PM
Black76's Avatar
Black76
Default Questions front end
I have the engine out doing a rebuild. I had play in the steering box do i replace with new steering box or upgrade to the steeriods system. And second question do i just replace all the bushings up front or upgrade to a mono leaf spring system any one using that system does it really improve handling
Old May 20, 2008 | 01:31 PM
Jims79's Avatar
Jims79
I think the question is how much $$$ do you have & want to spend?
my .02 I would go w/the steeriods system, new coil springs 550lbs & rear mono leaf 360lb, all new rubber bushings front & rear & four new bilstein shocks. Your C3 will handle like a C5
Binnie77's Avatar
Binnie77
Your upgrade here will depend on how deep your wallet is. I have both steeroids and monoleaf and I would never change back. There is no question that there is a dramatic improvement in handling. I do find the ride a bit harsher because of where I have my monospring set. The nice thing about the monospring is that is adjustable for both ride and height. With this setup, the only other bushings you need to worry about will be the sway bar bushings and upper control arms unless you change those out as well.
http://corvettec3.ca/steeroid.jpg
Vette Brakes also have a rack and pinion kit as well as Speed Direct.
Old May 20, 2008 | 01:39 PM
Black76's Avatar
Black76
I have a compasite leaf in the back and i allready installed bilsteins all around the kit for the front composite spring comes with new upper control arms has any body used that set up as far as money goes the price really doesnt matter
Old May 20, 2008 | 01:55 PM
stinger12's Avatar
stinger12
Rebuild your stock steering box with custom pitman shaft bushings.
To Questions front end
