Pump removal
Old May 21, 2008 | 04:47 PM
GreenDream's Avatar
GreenDream
Default Pump removal
I am about to remove the pollution pump and 50 pounds of assorted attachments from my 81. Other than plugging the vacumns and removing and blocking the EGR, what other problems might I run into?
My cat is gone as I have installed side pipes. Thanks...
Old May 21, 2008 | 06:10 PM
Durango_Boy's Avatar
Durango_Boy
Probably no problems.
Old May 21, 2008 | 06:22 PM
mrvette's Avatar
mrvette
Assuming you have a good carb tuned by a PRO, and not some rebuilt, you should have no issues, but when going that route, I think you should also replace the intake mani at minimum, along with a LARS carb....
course, IMO, nothing beats DPFI......but that's another thread....
the elimination of EGR seems to cause a tip in stumble with the off idle transferr circuit, i'ts the way it was esplained to me years ago, anyway...so your stock Qjet replacement maybe running a tad lean on tip in....nothing to do with secondary operation....
Old May 22, 2008 | 11:30 AM
GreenDream's Avatar
GreenDream
Thanks MRVette. I will most likely be sending my Qjet to Lars over the next winter and will consider a manifold at his recommendation. But for now the Qjet is operating fine. I just want to get rid of the pump and junk so I can at least see my engine.
To Pump removal
