tach i need help
Old May 22, 2008 | 01:07 PM
chemo's Avatar
chemo
Cruising
Default tach i need help
i just put a new circut board in my tach and the neddel is starting out on 20 how do you move the neddel to zero
thank
Old May 22, 2008 | 01:12 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
thank
Did you get instructions with the circuit board and follow them? What year is the car? It makes a diff
Old May 22, 2008 | 03:09 PM
chvet73's Avatar
chvet73
Those tachs will sit at the RPM where you shut the car off. Don't expect it to go to zero. If it functions fine while running than it's OK. Now if never goes below 20 than there is definetly something wrong.
Old May 22, 2008 | 03:38 PM
chemo's Avatar
chemo
Cruising
yes i followed the instructions it is a 1975
the tach opperates fine but it will not go below 2000rpms
when i put the key in the ignition it will go to two grand like it is zero
Old May 22, 2008 | 03:46 PM
at3erdbase's Avatar
at3erdbase
did you buy it from ebay
that alone could be the problem
seriously, They are calibrated for all apps.
it sounds like yours is just defective
all that i have driven go up to 15 after you turn the eng off
they go back to idle when you start you car
Old May 22, 2008 | 04:01 PM
chemo's Avatar
chemo
Cruising
no i got it from ecklers
can you remove the neddel then put it back on in the right place
Old May 22, 2008 | 04:59 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Yes, that is how I calibrated mine.
Mine came with instructions on how the do it, I don't remember all of it, but basically you remove the needle (carefully), supply + and - to the tach, then put the needle back on at zero.
Old May 22, 2008 | 05:03 PM
chemo's Avatar
chemo
Cruising
how do you remove the neddel and as for the power sourse can i just plug it in to the car thank you so much
Old May 22, 2008 | 05:26 PM
chemo's Avatar
chemo
Cruising
thank you so much i got the neddel off pluged it in then pluged it back into the car then put the neddel back on works grate once again thank you
Old May 22, 2008 | 05:38 PM
ccs96's Avatar
ccs96
Glad it worked out!
To tach i need help
