What is that!?!
Old May 22, 2008 | 04:22 PM
chevyfas's Avatar
chevyfas
Cruising
Default What is that!?!
I just swapped the carb on my motor, now there is this really loud whine coming from i dont know where, and the motor is idleing at 2000RPM. Its a holley 750 cfm double pump, the thing is, the car REALLY moves now, but i cant get it under 2000 rpm, and that whine is scaring the crap out of me!
Old May 22, 2008 | 04:27 PM
BB72's Avatar
BB72
Is it a female carb ? That would explain the ....nevermind
Old May 22, 2008 | 05:36 PM
chevyfas's Avatar
chevyfas
Cruising
actually, the whine sounds very much like a supercharger....which is kinda cool, but very annoying, like a whining female
Old May 22, 2008 | 05:41 PM
Durango_Boy's Avatar
Durango_Boy
You probably have a severe air leak in the carb. Hold the choke blade open and peer in and check the primary throttle butterflies down at the bottom. You need to make sure they are completely closing. It's possible something is interfering with either the butterflies themselves or the linkages. If they are completely closed when the gas pedal is not being pressed then check the edges under the carb for an air leak.
Old May 22, 2008 | 08:03 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
stupid question, but did you adjust the idle?
Old May 23, 2008 | 08:56 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
that whine is usually associated with a bad or blown gasket either at the intake, or if you have a q jet possible at the airhorn
cheers
Old May 23, 2008 | 11:58 AM
pws69's Avatar
pws69
Most probably a vacuum leak - would explain the high idle and the whine / whistle.
Old May 24, 2008 | 08:26 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
No info in your profile. what carb did you take off? Did you put a square base carb on a q-jet manifold? You will need an adapter plate if you did. It will have a vacuum leak without it.
Old May 24, 2008 | 08:14 PM
chevyfas's Avatar
chevyfas
Cruising
I figure the only way to fix it would be to remove the damn carb and start over, new gasket, etc, fired it up, and presto! no whining! adjusted the carb a couple of times, and no high idle! happy now that i can drive it again. thanks for the help guys!
To What is that!?!
