vacuum line question
Old May 23, 2008 | 05:58 PM
steeldust's Avatar
steeldust
3rd Gear
Default vacuum line question
need help with a missing vacuum line ... 1981 vette on the left valve cover a vacuum connection (double stack) my top line is missing. where does the other end go? pic or diagrahm thanks
Old May 23, 2008 | 08:33 PM
steeldust's Avatar
steeldust
3rd Gear
that is the pcv valve with two vacuum connections but only has the large (bottom hose) connected
Old May 23, 2008 | 09:21 PM
BarryK's Avatar
BarryK
my '78 PCV valve only has the one connection, never saw a PCV valve with two so don't know the answer for you but it would be in your AIM if you have one. If you don't have the AIM for your car you really should.
Old May 23, 2008 | 09:49 PM
Dirtbuster1's Avatar
Dirtbuster1
Do you mean back on intake by left valve cover?
Old May 23, 2008 | 10:07 PM
steeldust's Avatar
steeldust
3rd Gear
no, it is on the left valve cover, oil filler cap on back and this is on the front side towards the front bumper
Old May 25, 2008 | 02:46 PM
Dirtbuster1
On my 82, one to the PCV & the other to the charcoal cannister. It is a smaller diameter line.
Old May 25, 2008 | 03:56 PM
cajos's Avatar
cajos
Any pictures?
To vacuum line question
