TBI conversion
Old May 24, 2008 | 12:23 AM
7t5's Avatar
7t5
St. Jude Donor '14
Default TBI conversion
I was wondering if anyone here did a TBI conversion by doing a junkyard crawl to find all of the needed components. It seems like it would be fairly easy if you could pull everything off of one donor car.
Old May 24, 2008 | 08:22 AM
MN80Vette's Avatar
MN80Vette
I can't answer your question (I bought a Holley 4bbl TBI kit), but guys at the EFI Forum ChevyTalk.com have done it.
Old May 24, 2008 | 09:18 PM
wombvette's Avatar
wombvette
Got all of mine out of an 89 Corvette, wiring, computer and all.
Old May 24, 2008 | 09:33 PM
7t5's Avatar
7t5
St. Jude Donor '14
Well, that would probably be TPI. Thanks, though. That whole thing seems to be more involved than I want to get.
Old May 24, 2008 | 09:40 PM
wombvette's Avatar
wombvette
Ops, yea sorry I thought you said TPI. I dont see why TBI would be any different.
Old May 24, 2008 | 09:41 PM
chvet73's Avatar
chvet73
I have it but did not do it with a junkyard crawl. I got a kit from Howell, who lacks in customer service skills. One issue with the factory TBI is the throttle body is less than 400 CFM. Nice thing about the Howell kit it uses the Holley 670CFM throttle body. After I sorted out all the issues it runs very well.
Now with that said if I had to do it again for the same effort I would go with a TPI setup. It is a better system and should not cost much more.
Old May 25, 2008 | 02:28 AM
Kellys~hotrods's Avatar
Kellys~hotrods
I read an article or two about getting decent power from tbi on a low budget so it can be done, just have to do your homework.
Old May 25, 2008 | 02:53 AM
chevygod's Avatar
chevygod
Not a Vette, but a learning experience that will be used on one.
I converted my 79 GMC van from I6/TH350 to '87 5.7-TBI/700R4, using a complete donor van (motor, trans, ALL wiring and fuel system), hooked it up, and was able to pull off a California BAR buy off as a smog legal install. Starts easily and idles fine, pulls hard, fuel mileage is much better (about 20%). As I said, a learning experience.
I plan on adding TBI to my Vette during its rebuild, using a spread bore manifold and a '91 Big Block TBI-to-manifold adaptor. This allows adding the throttle body to a better manifold, getting a hot water flow to control icing, and have it all setup looking pretty stock under a factory air cleaner. And, Yes, you can get decent (tho not racecar) power out of a TBI setup.
Best, Tom
Old May 25, 2008 | 05:57 PM
cduemig's Avatar
cduemig
I was going to do this conversion to my stock 350 in my 74, but soon after I bought the stuff, the engine died. I replaced it with a 440hp 383 and don't want TBI for it so if you want the components I have I'm sure we could work out a good deal. I've got the intake (cleaned and bead blasted), rebuilt throttle body, some sensors, and a new GM computer in the box.
Old May 25, 2008 | 10:03 PM
Fast81's Avatar
Fast81
Look for Holley Pro-Jection 2DI (2brl)and 4DI's (4brl) on ebay.
these older TBI systems didn't need a laptop to tune them, just set screws on the CPU. The 2DI should handle 350-400 hp on a 350/355 but I'd go 4DI on anything with more cubic inches or HP.
Old May 26, 2008 | 08:01 PM
7t5's Avatar
7t5
St. Jude Donor '14
Does it have a harness? PM details and price.
Old May 27, 2008 | 06:09 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Corvette Fever did an article on it about a year ago.
www.diy-efi/gmecm has a lot of good swapping info, and there are several good "fuel injection parts swap" books available through Amazon or your local bookstore.
Old May 28, 2008 | 04:42 PM
7t5's Avatar
7t5
St. Jude Donor '14
Wow, that stuff is deep. Like a bunch of tech nerds using a foreign language or something! Thanks for the heads up, maybe I can have someone interpret it for me. BTW, correct link is
www.diy-efi.org/gmecm
Old May 28, 2008 | 05:02 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Whoops. Thanks for the URL catch. A lot of the modding stuff isn't necessary for a stock engine, but there is some useful info on basic swaps buried in there.
Old May 28, 2008 | 05:16 PM
7t5's Avatar
7t5
St. Jude Donor '14
Have you installed this system and what issues did you come up against?
Old May 28, 2008 | 07:59 PM
DR.Jay's Avatar
DR.Jay
I did the TPI conversion last year, and it isn't that much more complicated than TBI. The real differance is the air cleaner. (less plumbing) Other than that the install is about the same.
Here is a link to the thread I posted:
http://forums.corvetteforum.com/show...&highlight=TPI
Alot of the info on the install of the TPI will be the same as TBI. A pre '93 F-body is an excellent donor for the TBI, since the wire harness fits very well in a C-3 Vette.
Good Luck with what ever route you choose.
Old Jun 6, 2008 | 10:08 PM
busynick's Avatar
busynick
I am looking to do the same, what is the going price on this type of set up? seems to be a few on craigslist.com
To TBI conversion
Old Oct 19, 2008 | 09:18 AM
1982CorvetteDude's Avatar
1982CorvetteDude
Here's the article from Corvette Fever on swapping out to TBI using about $400 worth of junkyard parts.
http://www.mediafire.com/?sharekey=e...7ee78406a5aa0e
Mediafire has a lot of ads and pop ups - if anyone has a suggestion of a better site to host (free) let me know.
Old Oct 19, 2008 | 09:31 AM
covet's Avatar
covet
Cruising
Default X-Ram option
Hi
I am in the process of installing the X-Ram manifold which means I can keep the standard TBI/engine management etc. If you are interested have a look at:
http://www.x-ram.com
Cheers
Richard
Old Nov 1, 2008 | 05:58 PM
1982CorvetteDude
I have a TBI system for sale if anyone is interested in making the jump to Fuel injection. Came off a 1988 Camaro...
