Putting sidepipes on a 73? With Steeroids?
Old May 25, 2008 | 10:23 AM
ShaneLU97's Avatar
ShaneLU97
Default Putting sidepipes on a 73? With Steeroids?
I had a few questions about putting sidepipes on my car that I was hoping a few people could help me with.
First, I have the steeroids rack and pinion steering set-up so I am wondering if there are any fitment clearance issues with the kits on Mid Amderica.
Second, how difficult is the install? Anything hard about it? Do I need to drill any new holes anywhere or is this pretty much a bolt on?
I know I have to fill the exhaust panels in the back as well. Anyone use the panels from Mid America or Vettes by Design? I sent VBD an e-mail asking for pics or more information but never heard back.
Shane
Old May 25, 2008 | 09:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We have the factory install instructions posted on our web site. Doing the installation is not that hard but you do have to remove some of the lower fender which will only be exposed if you take off the rocker moulding.
You can view this file at this link. http://willcoxcorvette.com/repairand...lp.php?hID=199
On your 1973 car, you will need to either purchase an exhaust panel with “ears”, (see the ears sticking out to fill the old quarter panel holes.
Or you will need to run the 1969 rear exhaust panel for a car with side exhaust and fill in the area on the rear quarter panel where ½ the outlet is located.
I’m not sure about steroids getting in the way of the pipes. Someone else may have more experience with this and be able to help you.
Rear panel with ears http://willcoxcorvette.com/product_i...ducts_id=22634
Rear panels for 1969 with side exhaust in hand laid or press molded. http://willcoxcorvette.com/advanced_...anel.+w%2Fside
Willcox
Old May 25, 2008 | 10:51 PM
Kellys~hotrods's Avatar
Kellys~hotrods
I'll watch this thread because I want to add side pipes to my '69 vert Has anyone used/installed factory or aftermarket side pipes with steeriods?
Old May 26, 2008 | 12:49 AM
slvr76's Avatar
slvr76
I have the Hooker sidepipes on my 76 with the steeroids kit. I had to slightly dent one of the header tubes, but they will go on.
Old Jan 11, 2009 | 10:48 PM
ShaneLU97's Avatar
ShaneLU97
Any more detail? Which side did you have an issue? Where di you have to dent the headers? What was the interference point?
Any other tips?
Shane
To Putting sidepipes on a 73? With Steeroids?
