Felpro one piece gaskets
Old May 25, 2008 | 06:01 PM
72-LT1's Avatar
72-LT1
Default Felpro one piece gaskets
Can anyone confirm my oil pan gasket if the measurement is pretty much 2 3/8" from a flat serface to the middle of the front seal on the pan. Pan seems strait no wobbles.
All of the vendor sites say it should be the felpro OS34509T, but that gasket sure seemed a little short.
Would the OS34510T be the one to buy then. I guess if the 09T was just a little short then this would be the one.
Thanks all
Old May 25, 2008 | 10:30 PM
Scott Marzahl's Avatar
Scott Marzahl
Flip the pan upside-down on a flat surface without the gasket and measure the height from the flat surface to 12 o'clock on the sealing flange; if it's 2-1/4", it takes the "thin" seal - if it's 2-3/8", it takes the "thick" seal.
Fel-Pro blue 1 piece gasket # FPP-1880 is the thick version for 1975 and newer engines.
Fel-Pro blue 1 piece gasket #FPP-1885 is the thin version for the 1975 and older engines.
