Carpet from HELL
Old May 26, 2008 | 08:10 PM
glassman74's Avatar
glassman74
Default Carpet from HELL
Just finshed installing new carpet from Wixcox in my 74 coupe.
One whole day just on the f**king wheel wells. Carpet was from ACC. Boy those guys need to rework their preform molds. They
SUCK. Rest of it went well. Got some other int. stuff to put
in. My int. is med. saddle. I think every vendor has their own color.
Nothing I have bought matches. Have to repaint everything to
get it close.
From one Vet to the other out there, have a great day.
glassman74
Old May 26, 2008 | 08:49 PM
AimHigh's Avatar
AimHigh
I feel ya, I had to take my acc stuff and cut and clip it to fit as well. For what you pay you would expect more. It was a laugh for my wife though seeing my biggggg butt holed up in the well there trying to get it cut and fitted!
Old May 27, 2008 | 12:22 AM
wallifishrmn's Avatar
wallifishrmn
Got mine from ACC. Had to do alot of cutting. Never could find any carpet that matched my orginal green 1971. Every one had a slightly different color--picked the closest.
Old May 27, 2008 | 09:44 AM
Chadborne's Avatar
Chadborne
Default 1970 Green Carpet
I need to replace all of the carpet in a 1970 I just bought. Any suggested sources for precut carpet and padding?
Does the basic jute padding work well enough or do you suggest the heat/noise reducing carpet padding?
Old May 27, 2008 | 11:06 AM
jd1a's Avatar
jd1a
Great, my carpet from ACC just arrived. I wish I would have known this before I ordered. This was supposed to be Bloomington quality. From the sounds it's back street quality. I'll find out soon.
Old May 27, 2008 | 11:16 AM
cajos's Avatar
cajos
Hmmm, I was looking forward this one, now well . . . . . sigh
Old May 27, 2008 | 11:25 AM
wallifishrmn
It doesn't matter who you order your carpet from there are only 1 or 2 suppliers. One is ACC. I put the heat reflective material down first. I only used glue on the vertical surface behind the seats. My carpet needs some hot sun to help it flatten out. Two words of advice before you start: 1. take pictures of the inside and carpet before you remove it; and 2. keep the old carpet until you are finished. I did neither and had a heck of a time figuring out how things went back in. Replace the drain tubes that go to the rear wheel wells while you are at it. I also redid the vents by your feet.
Old May 27, 2008 | 11:53 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
crap! My carpet from ACC has been sitting on the shelf in the shop while I finish the interior with reflectix and dynomat! Another fun day in the vette to look forward to!
Old May 27, 2008 | 12:03 PM
75 Red Vert's Avatar
75 Red Vert
Be sure & save your old carpet, it will help out. The replacement carpeting over the rear wheels is an absolute b#$%@^ to get it to fit right in a vert.
Old May 27, 2008 | 01:01 PM
pws69's Avatar
pws69
CRAP! Mine is sitting in the box waiting to go in - I'm so looking forward to it now!!
To Carpet from HELL
