Ride height and level
My 75 C3 rides and drives great for the most part, aside from hating the Q-jet I really love my car. However, am I being picky or could there be a reason for my concern on my ride being level? My left side (driver) is exactly one (1) inch higher than my right (passenger) side. For the life of me I can't think this is correct except for the fact that this is a thirty something year old car and the springs could be a little weak.
Or, maybe its supposed to compress that extra inch on the left side with my big butt and a full tank of gas.
Am I being picky or should I shut up and color and just enjoy having the opportunity of being where I am now?
thanks!!
My 79 sits higher on the pass side than the driver side by about 3/8.
I had to adjust the rear spring bolts to get a level ride.
But an Inch is alot.
Check your rear spring bolts to make sure they are adjusted equally.
Have the front springs been out? Maybe they are not seated correctly?
How are your body mounts?
QUOTE]
Same thing with my 76, haven't figured it out yet.
took the sping out and reversed it,.,,,,,still sits the same.
Installed all new bushings and made the sure all was right.
Still sits the same.
Trailing arms are brand new so there should be no issue with anything related to there.
took by bolts for the spring hangar on the end where it connects to the trailing arm,,,,,went to the machine shop and added 3 more inches of threads to them so that I can raise the car if I want. Everyone on the forum always says out is down and in is up.
Went back home and put it together... car still sits 1 inch off from the passenger side whatever I set the drivers side to.
I can cinch the passenger side all the way in (almost 3 inches shorter on the bolt than stock) and the car still wont go up on the passenger side.
WHAT IN THE WORLD IS THIS!!!!
GM checked the ride height to the frame, NOT to the top of the fender like we all do now.
You've got 4 corners and they are all inter-related. Try disconnecting the front sway bar and the rear bar if you have one then drive it around a bit before you check it again.
the passenger side is 4.75 inches off the ground and the drivers side is 5.25 inches off of the ground.
does this help any?
I measured at two points of the frame on each side coming from the front. Each point has the passenger side 1 inch lower than the drivers side.
Could this be a front spring issue maybe?
You've got 4 corners and they are all inter-related. "
the front can have an impact ( a lot more than you would think) on the rear, the front springs are generally a lot stiffer than the rears.
1979toy,didn't mean to steal the quote, just don't know how to do it the right way
