What did I break now??
Old May 27, 2008 | 01:11 AM
tomard's Avatar
tomard
Default What did I break now??
A small nipple with wire at firewall, right behind the RH side valve cover .....
Tried to put arrows, but not sure they show up very well ....
Anybody know WHAT that wire is for, and if I can possibly remove the nipple and maybe crimp wire back on .....
http://i244.photobucket.com/albums/g...BrokenWire.jpg
Old May 27, 2008 | 06:49 AM
...Roger...'s Avatar
...Roger...
First where does the engine side of the wire go? 2nd are you sure its a wire and not a small vacuum hose.3rd are you sure it went to that nipple because those nipples usually are used to hold carpet or padding?
Old May 27, 2008 | 09:02 AM
tomard's Avatar
tomard
It is the ground wire for the tach filter It didn't have anything to do with that nipple ..... which I hear is what is used to hold carpet etc on inside cab ....
Old May 27, 2008 | 12:02 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
that what it does on my car, holds the insulation to the firewall....
To What did I break now??
