T Top Windseild Corners
Old May 27, 2008 | 11:43 AM
JHPOWER's Avatar
JHPOWER
Cruising
Default T Top Windseild Corners
Can Any Tell Me How To Change Them And Is It A Hard Job. Mine Have Minor Pits But May Change Them If Not To Hard. 74 Vettte
Old May 27, 2008 | 12:59 PM
lr172's Avatar
lr172
Two of the screws holding this cast piece onto the windshiled frame are at the front of the frame and you may have a difficult if not impossible time getting these out with the windshield installed. My windshield was out when I did it so I can't say for certain. At a minimum, you will be at a significant agle when approaching the screw. Be advised, it only takes a small chip/crack on the edge of the windshiled to create a nice, full length crack that magically appears an hour later. Ask me how I know.
Good luck.
Old May 27, 2008 | 01:10 PM
cajos's Avatar
cajos
I forced the first one out only to find there are more screws just above the windshield. I wanted to reuse them now is broken. So don't force them they break easily clean the area above the windshield to find the screws.
Old May 27, 2008 | 06:54 PM
78Vette-SA's Avatar
78Vette-SA
When you get them off one depending on what look you want then can be refinished or in my case I sanded all the pits down and had them powdercoated. Just an option and was cheap.
To T Top Windseild Corners
