My New Bumper Seems Flex At Bottom In Center But Do Not See Any Brackets To Hold Still .am I Missing So Parts .and Does Some One Have Diagram Or Photo 74
JH,
The only thing that holds the bumber on are the 18 10-32 bolts
around the lip that bolts to the body that I know of.
My fiberglass cover on my 74 flexed in the bottom crnter. There are two angle braces that attach to the bottom of the license plate area and angle up and forward to a frame cross member. Its different than the illustration of the 75 posted by Jud Chapin.
You can buy some flat steel or alum strips (1" wide) and drill some holes (slots prefered) and bend into proper angle. That's what I did after my fiber ones broke.
...actually, because of the way the '74 taillights are mounted independently of the rear bumper itself, the '74 rear bumper replacement is much easier to do than the '75 to '82 cars are.
