Water Pump Studs, Locktite?
Old Jun 1, 2008 | 10:25 AM
72-LT1's Avatar
72-LT1
Default Water Pump Studs, Locktite?
How far throught the WP flange should the new studs go? and should you use any locktite to keep them in or is it not necessary.
Rob
Old Jun 1, 2008 | 11:54 AM
TimAT's Avatar
TimAT
one or two threads is plenty- the shoulder on the stud usually bottoms out on the front of the wp flange. Locktite not needed.
Old Jun 2, 2008 | 07:31 AM
RunningMan373's Avatar
RunningMan373
Recomend anti-seize rather then locktite. Nothing like a sheared W/P stud- . they won't come loose.
Old Jun 2, 2008 | 07:43 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
No Locktite.
To Water Pump Studs, Locktite?
