what thermostat?
Should I consider putting the fan clutch back?
Will I have less temperature swings with it?
If so, than definitely install it back on the car along with the correct stock fanblade (avoid flexfans at all cost, they are not as efficient and tend to break off blades taking large chunks of fiberglass with them when they go
)Also make sure the correct fan shroud is installed and all the proper radiator and core support seals are in place.
Than make sure your vacuum advance is connected to a full manifold vacuum source and working correctly and your car should run at proper operating temps.
I was stuck in traffic the other day for about 5-10 minutes, ambient temp was about 80°. The temp gauge moved towards hot about one needle width, and came back down to the normal position after just a minute of moving.
Here is my temp gauge with the two thermostats I mentioned.
Cheers,
Pete
http://www.corvettefaq.com/c3/fanclutch1.doc
http://www.corvettefaq.com/c3/fanclutch2.doc
http://www.corvettefaq.com/c3/fanclutch3.doc
Yes, the t-stat only controls minimum operating temps, not maximum temps or what the motor will actually want to run at but if the cooling system is up to par is very possible to have it keep cool enough to stay at the actual t-stat temp range. There are people that put in 180º stats and the cars stay right at 180 and some people can put in a 160 stat and the car will run right at 160 if the cooling system is working efficiently enough.
If that were the case than having a 160 t-stat in there and having the car operate at 160 is to low, it's not a high enough operating temp to completely burn off excess vapors and that can create condensation and sludge in the oil - not good.
As for sludge formation, a 160 thermostat is absolutely too high to contribute to that. Running no thermostat, depending on how good you cooling system is, could get you into a sluge formation condition.
With all this said, if you change your oil often enough, neither sludge nor acid formation will be a real issue, even if running cold, because the oil's additive package will keep these concerns at bay.
no, I'm not confusing coolant temps with oil temps at all. I'm not discussing oil temps, i'm discussing COOLANT temps.
try reading this article by John Hinckley, a former GM engineer, specifically the section on thermostats.
http://lbfun.com/Corvette/Tech/vette...es/cooling.pdf
If you wish to run a 160º t-stat in your car, be my guest but it's not the correct thing to do and your motor isn't liking you for it.
It takes too long to warm up the engine which can promote sludge.
To help reduce emissions they added the A.I.R system, the EGR, and others. To make this equipment operate and do it's job the operating temps had to be raised to increase burn off of excess HC which was accomplished by raising the t-stat's from 180º to 195º and also by moving the vacuum advance to a Ported Vacuum connection and also lowering the initial timing settings. With no vacuum advance at idle now and a retarded timing setting the operating temps came up and the 195º t-stat made sure that the minimum operating temp would be 195º or higher. This helped reduce HC output to meet new federal emissions requirements.
The HEI distributor was now added because of the retarded timing and leaner fuel mixture required a hotter spark activity for proper combustion.
ahhh, the 70's emissions years.......... the dark days of performance!
(as if Disco wasn't bad enough during that time)
you are correct that the ENGINE didn't require the higher T-stat, just the emissions equipment that now had to be installed on them did to work correctly.
AWilson
If the emissions equipment is still installed on your car and your car still has to pass your states emission tests during inspection than you are best off keeping a 195º t-stat in there. If you don't need to worry about passing emissions tests or the emissions equipment has been removed from your car than go with a 180º t-stat.
Last and not least, but with all the information you need is in Barrys statement,
"Correct reproduction provides accurate resistance, connection, & gauge display. Note that water temp reading may vary from actual water temp + or - 10%. My emphasis.
180° minus 10% is 162° and 160° plus 10% is 176° Hey, yours should read higher than mine! LOL.
Cheers,
Pete
Maybe the author was not a hands-on engineer, there are countless types of engineering specialties. Believe me, I know, that is my own industry. And not only that, like all professions, let's just say, some are better than others. And the old saying, "those who can, do, and those who can't, teach", can certainly hold true here as well. I'm sure he means well, but don't bet the farm on everything he said being correct, because it doesn't all match reality. You should know by reading this forum, that members don't often agree on any given discussion. Authors and engineers are no different. You could find as many to disagree with him, as you could find who would agree with him. A word to the wise, be careful about believing everything you read on the internet. You might just shoot yourself in the foot……...
I'm not going to bother to argue about it. I know what I know from my own cars, from EVERYTHING I've researched and read, and also from people like John Hinckley and others who ALL say the same thing.
Sorry, when it comes to credibility I'll take results from OEM testing over that of a few gearhead buddies of yours. I'd say GM engineering had a few million more dollars to do their testing to come up with their results and conclusions.
BTW, the Robert Shaw thermostats, also sold under the Mr. Gasket brand name are what's considers a "Balanced Flow" thermostat. They have an extra set of passages for the coolant to flow thru in case it fails therefore coolant flow is not completely restricted in the event it fails - this is why it's commonly referred to as a unit that "fails open" rather than "fails closed". Other units that fail will completely restrict coolant flow but the Robert Shaw and Mr. Gasket units won't.
With all your comments about the author of the article I cited in your last two responses you may wish to learn a bit more about who John Hinckley is before attempting to discredit his information.... you may be a bit surprised.
be my guest, it's your car........
As I mentioned already, MOST peoples cooling systems aren't efficient enough that it's going to make much of a difference anyway meaning that the car is still going to run at an operating temp higher than the 160º anyway.
if your system is efficient enough to run an actual 160º operating temp once it's warmed up than it's your car that has a higher than normal wear on the piston rings and cylinder bores and possible condensation issues in the oil.
it ain't my car so do what you like
May I suggest that you relax a bit and cool out. What ever you believe in is fine, just don't try and force it on everyone else. No reason to be so authoritative on this, it just stirs people up. Everyone has had different experiences, good and bad, so offer your experiences and we will offer ours. That is the great thing about the people on this Forum.
Fred
A 160 is too cold at first but may just allow the coolent to pass through the radiator too fast and can actually become a factor in causing overheating.
Fred
Oh, and on your GTO (nice cars!
) it may have still ran great at 175K miles but if the motor was never apart how do you know there wasn't ANY additional wearing on the parts assuming the cooling system was keeping operating temps at the same 160º as the t-stat? Unless the actual operating temps were higher anyway which again makes the entire point moot. regardless, I'm done debating it
