73 with rusty rear roof?
Old Jun 1, 2008 | 05:29 PM
ChrisMiami's Avatar
ChrisMiami
Default 73 with rusty rear roof?
I just saw a 73 with so much rust under the T-tops that the metal has become a flake sandwich. It's primarily in the crossbar between the T-tops and the rear window. Sorry, I didn't get pics.
What kind of issue is this? Is it a drop-in replacement part (well, push up into place)? Or is it a saw the roof off and build another one kinda deal?
It gave me the heebs, as it looks irreparable.
Thanks, as always!
Chris
Old Jun 1, 2008 | 06:33 PM
Durango_Boy's Avatar
Durango_Boy
It can be cut out and repaired with new metal but it's a cut and weld kind o0f affair. That cross bar is part of the bird cage, which is the metal structure that makes up the cabin of the Corvette. You can't just unbolt part of it, it has to be cut out and a new structure welded in.
Old Jun 1, 2008 | 06:59 PM
V-Twin's Avatar
V-Twin
No need to cut, drill out the spot welds and a cold chisel and some whacks with the hammer and the t bar comes right out.
Old Jun 2, 2008 | 12:04 AM
Durango_Boy
If the cross bar is the only problem then V-twin is right, but if you have to replace material around the frame behind it...you can look forward to some cutting. It just depends on what you mean by primarily.
Old Jun 2, 2008 | 11:15 AM
ChrisMiami's Avatar
ChrisMiami
Default Thanks
Thanks for the info. I am looking forward to getting more experience - I think you guys might have jumped on it, but for me it was just too big a job first time out.
Oh well, live and learn...
Thanks again,
Chris
To 73 with rusty rear roof?
