My rear rotors are at the machine shop about to get turned. The guy just wanted to make sure of the minimum thickness the rotors can be turned without causing a problem. The book he had only went back to '74 and my car is a '69. Does any one know the minimum width a rotor should be? thanks
You may be getting more problems then you think if you don't check and correct the runout afterwards.
I'm also replacing my original rotors w/new ones and trying to figure out exactly how to check the runout myself. You had posted a link on another similar post yesterday to a site that was to explain the process but I couldn't navigate within the site when I tried the link. How exactly do you check for this on a vehicle where the rotor is not riveted to the hub? I assume this is a procedure that anyone who has a dial indicator can do at home. A brief explanation woudl be greatly appreciated.
Also - I'm trying to figure out how one would correct it if out of tolerance. Would a brand new rotor exhibit this problem?
I've been doing some searching of archives and see this topic has been discussed in detail and found the following link in another post that was very informative:
Not only does it cover runout check procedures in detail but discusses lots of other useful brake topics. Worth mentioning that if this is done while on car that you have to suck up all your bearing tolerance by torquing to 15ft.lbs. during the test or you'll be measuring your bearing play as well.
I also learned that it appears the hub can cause the runout issue as often as a rotor can so watch out for that.
In that post I setup front bearings and runout off the car. I have a spindle mounted in a vise to show how I do it.
Some vendors don't like me posting my procedures here so if you want me to go into detail post on the other site and I'll be glad to help you without any restrictions.
