Transmission Help!
Old Jun 4, 2008 | 02:04 PM
Apocolips's Avatar
Apocolips
Default Transmission Help!
I just changed the filter on my 1970 350 T400 transmission. Put everything back together and added about 2 1/2 quarts of transmission fluid. I started the car, put it in gear and nothing. So I added another 1/2 quart of fluid. This time it would move forward and backwards but with alot of throttle applied. When I shut down I heard a hissing sound and noticed fluid coming out of the transmission filler cap. Whats Up?
Old Jun 4, 2008 | 02:13 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
In changing the atf in a 350, you remove a little over 4 quarts. it sounds like you are low on fluid. I would add another 1/2 quart and then check the fluid level. This is done after the car is at operating temp, engine running, and car on level ground.
Old Jun 4, 2008 | 03:41 PM
Apocolips's Avatar
Apocolips
Just got back from the parts store and put 3 more quarts in. Works fine now. It just didn't seem like that much came out when I drained the pan. I put a total of 5 quarts in after the filter change. Now on to something else! Thanks
Old Jun 4, 2008 | 04:05 PM
Jud Chapin's Avatar
Jud Chapin
5 quarts seems a little on the high side. Be sure to check the fluid level as you don't want too much fluid in there.
To Transmission Help!
