master cylinder question
Old Dec 21, 2001 | 12:49 AM
KrAzYSnIpEr's Avatar
KrAzYSnIpEr
Default master cylinder question
i know this has been asked about a trillion times, but what do you prefer?
i have an autozone special right now and i am not having too much luck out of them, they seem to not want to seal very good, giving me a soft pedal unless i stab the brakes, then they still arent what they should be.
is the extra 50-75 bux worth it to get a new cylinder?
thanks guys
Old Dec 21, 2001 | 12:59 AM
daniel77350's Avatar
daniel77350
Default Re: master cylinder question (KrAzYSnIpEr)
my autozone special is in perfect working order ( :smash: on wood).
I think it has a lifetime warranty, you can try taking it back for a replacement...tell them the seals are bad.
Daniel
Old Dec 21, 2001 | 01:40 AM
LT1driver's Avatar
LT1driver
Default Re: master cylinder question (daniel77350)
Take it back and get a new one, until they give you a good one. Make sure you are bleeding both brakes AND master cylinder...bench bleed master before putting in on. Good luck. :cheers:
Old Dec 21, 2001 | 01:52 AM
KrAzYSnIpEr
Default Re: master cylinder question (LT1driver)
thanks guys, i guess ill take it off sometime this week...
To master cylinder question
