A/C question
Old Jun 5, 2008 | 07:31 PM
Brown78's Avatar
Brown78
Default A/C question
Everything in my A/C has been changed. Except the condenser. Now when it's running cold it stops and worm humid air comes out. I know it sounds like not enough 134. The system is full. Being the condenser is 30 years old could that be the problem maybe clogged?
Old Jun 5, 2008 | 07:55 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
for how long it will blow cold? .. sounds like the evaporator is freezing.
Old Jun 5, 2008 | 08:16 PM
Roughrider's Avatar
Roughrider
Does it have an expansion valve? That could be clogged or partially so.
Back in the day in a car I had the a/c wasn't operating well when suddenly there was an explosion under the hood. The expansion valve was clogged and the high side hose blew clean off the compressor. There was compressor oil everywhere under the hood and the hood insulation was shredded.
Old Jun 5, 2008 | 08:50 PM
Brown78's Avatar
Brown78
How do I stop that?
Old Jun 5, 2008 | 08:56 PM
S489's Avatar
S489
start with proper amount of freon i believe; should have been installed by weight, usually digital scale
Old Jun 5, 2008 | 09:23 PM
Brown78's Avatar
Brown78
I have had the system drained. And refilled with the proper amount.
Old Jun 5, 2008 | 10:13 PM
AimHigh's Avatar
AimHigh
could be the "clutch switch" (guys help me out if I'm using the wrong terminology) goes on top of the dryer I think and looks like a brake pressure switch. They go bad, sometimes you can tap it and the system will come back on, on mine I removed it and cleaned it and worked for a while. Finally replaced it and all it good.
hope this helps.
Old Jun 5, 2008 | 10:20 PM
Dirtbuster1's Avatar
Dirtbuster1
It would be the low pressure switch. I'm not sure what year car you have. If you converted it to 134, it should have 80% as much as the
R12. Overfilling 134 is as bad as under filling it.
Old Jun 5, 2008 | 10:33 PM
TopGunn's Avatar
TopGunn
It sounds like it's freezing up, mine did that due to a sticking POR valve but your system is different than mine. I got some good advice from this forum:
http://acsource.net/acforum/viewforum.php?f=1
Old Jun 6, 2008 | 06:53 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Does it cool again after you shut it down for a few minutes?
Old Jun 6, 2008 | 07:13 AM
AimHigh's Avatar
AimHigh
Good question!
Old Jun 6, 2008 | 09:36 AM
wnmech's Avatar
wnmech
When you notice the heat is the car idleing? If this is the case and you are still useing the engine driven fan your high pressure switch is causing the compressor to disengage. In our cars that were not originally for the new refrigerant at idle there is not enough air moving thru the condensor causing excessive high pressure on the system and the high pressure switch disengages the compressor. Something else you need to check is when the warm air is coming out of your vents verify if your compressor is engaged. If the compressor is still engaged you may have one of the under dash actuators moving to the open position allowing outside engine air in to your cabin.
Old Jun 6, 2008 | 10:13 AM
bmotojoe's Avatar
bmotojoe
First thing I would look for is frost. If you have excess amounts of liquid logging up in areas you will defiantly have a frost line. Because the evaporator is enclosed the frost line will be hard to see. I would pull the screws out of the thermostatic switch and let the switch sit on top of the evaporator housing and see if your compressor clutch stays energized. This switch is normally closed at temperatures above 34* and opens at temperatures below 33* disengaging the compressor clutch solenoid.
Old Jun 6, 2008 | 01:22 PM
Brown78's Avatar
Brown78
I don't have to shut it down. Just let it keep blowing and the cool air comes back on. Then after a while it will do it again. Warn,cold, warm,cold.
Old Jun 6, 2008 | 01:29 PM
Brown78's Avatar
Brown78
No I took the stock fan out, and replace it with dual electric fans. I installed a small pusher fan in front of the condenser. That comes on only when I turn the A/C on
Old Jun 6, 2008 | 02:13 PM
Jud Chapin's Avatar
Jud Chapin
Is the compressor cutting in and out when this happens?
Old Jun 6, 2008 | 06:18 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
If the the compressor keeps "cycling" on and off, and you have the updated POA valve that has the cycling switch, then it may indicate one (or both) of these cases, the refrigerant is low, or you need to adjust the small screw inside the switch.
of course there may be some other reasons, just want to give you a place to check.
BTW, how did you manage to have a pusher fan on your condenser? I was trying to have one on mine, but it seems if I put one on, I wont be able to open the hood anymore! .. very tight place!
To A/C question
Old Jun 6, 2008 | 07:44 PM
thegazman's Avatar
thegazman
Default thegazman
Could be moisture in the system freezing the refrigerant expands. If you turn the unit off for a few minutes and turn it back on will it start working again. If this is the case, moisture is probably present and thaws when the unit is off. The it will freeze up again as it passes through the system.
Old Jun 6, 2008 | 08:32 PM
Brown78's Avatar
Brown78
I cut 1" out of the hood latch and welded it back together. I still have plenty of room to take out the radiator
Old Jun 7, 2008 | 06:55 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Thats really a clever way! .. I will search for a set of used hood supports and will try it out. Thanks!
And about your A/C problem, any updates? have you found anything?
