VORTEC HEAD Choice????
Old Jun 6, 2008 | 06:24 PM
SpE3dF0x's Avatar
SpE3dF0x
"DB" would it wise to use the Self A ones or do you think the guides will work at high revs? In your words do you think it would be wise to purchase the Selfers as opposed to using guide plates?
Old Jun 6, 2008 | 11:14 PM
Durango_Boy's Avatar
Durango_Boy
I think if you're going to be 'rough' on the engine then guide plates and hardened push rods will be a better choice. However, make sure that the bottoms of the rockers don't come in contact with the base of the stud. The guide plates will raise the stud up, and in some cases create a clearance problem and you can't get the rockers adjusted without contact. Not always, but just be careful of it when you're assembling it and setting the rockers. Also, you want the tips of the rockers to pattern in the middle of the valve stem.
Old Jun 8, 2008 | 02:42 AM
OMF's Avatar
OMF
I used vortec heads on my stockcar and also had heard of the favoring of one casting over another, so I decided to do a test. I did a low tech comparison of both a 906 and a 062 casting. I had one of each on my bench and took both intake and exhaust valves out and then proceeded to make some measured and visual comparisons. Everything I measured and looked at was so close to one another that I'd say they were the same. I paid special attention to both of the valves and seats and determined that they were identical.
I think I remember reading that it was the early version that had a lower flowing exhaust seat, but since then the seats have been changed to reflect the better flowing ones.
I also looked at a vortec head once at a swap meet that had the nicely curved short side radius but did not have the heart shaped chamber. I'm not sure what that head came off of but I would stay away from anything without that heart shaped chamber.
I hope this bit of info helps.
Old Jun 8, 2008 | 08:38 AM
andylmusic76's Avatar
andylmusic76
buy a brand new set of vortecs from jegs...i did this in february $550 for everything plus free shipping!! works great! they are also stronger and have better seals if i'm not mistaken.
Old Jun 8, 2008 | 09:49 AM
L88Plus's Avatar
L88Plus
Don't rule out the new Bowtie Vortecs for higher hp/cube applications. I'm building a 406 with a set of their newly revised 225cc runner heads, look like they'll make great power. Should have dyno results within about a month.
Old Jun 9, 2008 | 01:42 AM
SpE3dF0x's Avatar
SpE3dF0x
550$$$!!!! Has anyone heard of the "three triangles" heads??
Old Jun 9, 2008 | 04:30 AM
gingerbreadman1977's Avatar
gingerbreadman1977
GM fastburns
Old Jun 9, 2008 | 03:08 PM
SpE3dF0x's Avatar
SpE3dF0x
Ginger is that what they are??? Are the three tri's GM FAST BURNers? I thought the GM FAST BURNERS had the GM logo with the checkered flag? Also is it possible to use this cam with stock Vortec Heads(062's/906's)
Brand: Edelbrock
Product Line: Edelbrock Performer-Plus Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Part Number: EDL-2102
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: Idle-5,500
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 288
Advertised Duration: 278 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: Yes
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
Quantity: Sold as a kit
Any thoughts...I'm not trying hit MACH speeds or anything that's why I have a sport bike. But just a little pep in the step!
Old Jun 10, 2008 | 02:38 AM
gingerbreadman1977
the only place you will see anything is here on the front and back of the heads. all it says is GM performance parts with the flag logo. doesnt actually say fastburn.once the heads are covered with brackets for alt and aircon you dont see much of it at all.
