Pulled my transmission out today ?
Old Jun 5, 2008 | 09:03 PM
BB427's Avatar
BB427
Default Pulled my transmission out today ?
Yank out my trans today so I could change the clutch. I'm putting in a new Clutch , Pressure plate , Throw out bearing , Pilot bearing , & resurfacing the fly wheel.
Is there anything else I should change while I have everything apart ?
So Idont have to pull that Bi**h back out
PS the 10 spline shaft Had some circular play in it I knowit slidesinto the crank but should I be worried . Staring at the shaft straight on it move about 1/8-3/16 in any direction.
Old Jun 5, 2008 | 09:19 PM
Durango_Boy's Avatar
Durango_Boy
It's a good time to make sure all the linkages are tight and nothing is loose or binding.
I would be worried with that much slop in the shaft. Maybe someone better with manual transmissions will chime in.
Old Jun 5, 2008 | 09:48 PM
Gordonm's Avatar
Gordonm
Check the clutch fork where it contacts the throwout bearing. Make sure the fingers are not worn down to much. A new fork is relativly cheap if it has never been replaced before.
The play in the input shaft is fairly normal for a trans with some miles on it. How did it shift before removing it. You might want to pull off the side cover and look at the syncros and gears to make sure nothing is chipped or broken. Now is the time to check this while it is on the ground.
Old Jun 5, 2008 | 10:57 PM
72LS1Vette's Avatar
72LS1Vette
Unless you are using a new motor I would change the rear crank seal while everything is apart also.
Rick B.
Old Jun 5, 2008 | 11:12 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
All of the TKO vendors talk about the importance of centering the bellhousing in relation to the pilot bearing. I know that very few people did it back in the 60's and 70's. Of course the trannies were not as precision as they are now. Case in point, using 90W then versus ATF or GM syncromesh lube now. Any thoughts on the procedure?
Old Jun 6, 2008 | 09:27 AM
OldSchool's Avatar
OldSchool
With the driveshaft down, time to replace the u joints too.. Cheap insurance if they havent been replaced recently or ever...
Old Jun 6, 2008 | 09:43 AM
crossram's Avatar
crossram
I dont know why you two guys are always at each others throat.
Life is short and you guys are burning it up with this?
Old Jun 6, 2008 | 09:46 AM
GDaina's Avatar
GDaina
Have a beer, enjoy life, be happy
Old Jun 6, 2008 | 12:42 PM
BB427's Avatar
BB427
Okay Clutch fork ,pilot bearing, U-Joints , It shifted perfect hurst shifterhad metal bar linkage but I will check it out and the gears.
Old Jun 6, 2008 | 02:11 PM
Gordonm's Avatar
Gordonm
Now you have me curious. What does the clutch disc and flywheel look like. Was the disc frozen to the flywheel? Is there surface rust on the flywheel?
Old Jun 6, 2008 | 08:23 PM
BB427's Avatar
BB427
It was seized to the pressure plate I had to whack it with a 28oz ballpean hammer to seperate them yess the fly wheel and pressue plate both had surface rust .Last time we drove the car got caught inthe rain and I dont have that metal cover that goes in front of the bell hosing behind the fly wheel.
To Pulled my transmission out today ?
